Display Issues white screen
Hello,
I have the display problem from past few days i tried re installing IOS but still i have the same issue. Please advise
Mac book pro Retina late 2013 15” 2.03 Mhz
Hello,
Sorry to tell you your display is damaged. Somehow your system got sat on or banged, damaging the LCD inside. You’ll need a new display assembly. Here’s the IFIXIT guide you’ll need to follow: MacBook Pro 15" Retina Display Late 2013 Display Assembly Replacement and here’s the needed part: MacBook Pro 15" Retina (Late 2013-Mid 2014) Display Assembly
Looking at your Samsung display it too has a display issue! The horizontal line is what we call a TAB error which is where the metal oxide trace on the glass has broken on a few of the horizontal lines.
Thank you !!
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 372
2 Comments
can you elaborate the issue you are facing
by Amily Grey
Amily,
I think its clear the display is bad the first image shows the internal screen with the colored bars. In the screen behind it you see the desktop. If you look carefully you can see in the second image the HDMI connection to the Samsung display. Also note the green haze on the 3rd & 4th image.
Unlike the older LVDS based systems where a loose or bad cable could be the cause. In the newer retina systems the signaling was changed to iDP (eDP) which sends s different kind signal similar to how analog to digital TV changed. iDP signaling is an all or nothing type of signal like how your digital TV works or if intermittent you get blocks like your digital TV.
The condition here is the decoder on the LCD panel which converts the iDP to the needed signaling for the LCD display its self has failed. Thats why Shark DJ needs a new display.
by Dan
