The Kenmore Elite HE3 is a washing machine by Kenmore.
551 Questions View all
Why is the washer heating my cold water wash cycle?
If I put my washer onto a cold/cold cycle, my clothes still come out hot. I even shut off the hot water inlet going into the unit to prevent this. Could this be a ATC problem?
Add a comment
Chosen Solution
Sounds like you're getting hot water from the cold water inlet. This could happen if the water hose connections have been reversed. Try running on a hot cycle, if I'm correct the water will be cold.
Score 1
I will try this tonight - crazy how something like this could possibly be so simple. Thanks very much!
Occam's Razor - The principle is often inaccurately summarized as "the simplest explanation is most likely the correct one." But it works.
Add a comment
sounds like your mixer is bad. I had that happen and just turned off my tankless water heater to get cold water when I realized my mixer was bad
Add a comment
Add your answer
pegasidreams will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 48
All Time: 2,832
