Repair guides, techniques and disassembly information for Android smartphones manufactured by Xiaomi.
1667 Questions View all
[Redmi 3 pro] Loose cellular network when back cover clipped back on
Device : Xiaomi Redmi 3 pro
After replacing the battery, the mobile network doesn’t work when back cover is properly clipped back on. After testing, it works fine without the back cover and absolutely not when back cover is clipped back on.
I double checked all the internal connectors (one was bent so I straightened it back) and tape antenna. I tried loosening or tightening screws. I tried to replace the old battery (matter of the 1mm difference) without success.
I lack magnifying glass so not easy to check if a component is damaged (but why would it work without the back cover?).
Add a comment
1 Answer
It sounds like something is blocking or causing interfarance . Try removing all the screens n put the black cover on to see if that fixes it. If it does put one screw in at a time then check to see if it still working or not .
1 Comment:
I'll give it a try at some time.
Not sure it will fix as I already tried to loosen screws without success.
Putting the SIM card in the other port gives various results but ends up failing.
by
Add a comment
Add your answer
Nick TNTPOP will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 57
