How HD iPod 30 gb and 160 gb?
I wanna know if there's a way or a kit, to use my ipods hard drives like external?
This here shows you how to use your ipod as an external drive. If you are thinking about using just your harddrive you will require a USB-to-Zif adapter. They are available at eBay for about $5 When plugged in your OS system should see that drive as an external hdd. Good Luck to you.
I appreciated your answer. But in the case of my 160gb the connector is different, is small. You have to excuse my English, because I’m Mexican.
jorgearmandorosas, your English is great. The connector on your drive takes a small flat cable and uses a clip to keep the cable locked. That is called a Zif connector. You can get Zif-to-USB adapter on ebay. I have a couple that I use all the time to test the Hard drive. Something like you see on here http://www.addonics.com/products/io/aaed... But just do a search on ebay and see if they have what you need. If not contact me and I get you one ;-) and thank you for accepting my answer.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 1,656
1 Comment
jorgearmandorosas just the hard drive or the whole ipod?
by oldturkey03
