Model A1136 / 30, 60, or 80 GB hard drive / black or white plastic front
844 Questions View all
Replace battery, but iPod very slow response
I just replaced the battery, and plugged it in to charge. But the iPod is very slow to respond
ADMIN EDIT: Here is the entire context for the question. For those of you who are answering, please look at the context of the question to best answer: My iPod keeps erasing the memory every few days., My ipod is corrupted, Replace battery, but iPod very slow response, Replace battery, had to restore, now it says it cannot be restored, Error 1437, If I delete itunes..., Well I deleted itunes..., Ok either hard drive or logic board?, Hard drive brands.
Add a comment
Chosen Solution
Have you ever defragmented and optimized your hard drive? Your songs may be scattered all over your drive and it can take a long time to seek them. Tech Tool Pro http://www.micromat.com/ is excellent for this.
Score 1
Add a comment
Most Helpful Answer
I recommend resetting the iPod by toggling the hold switch on and off and then holding the menu and center buttons down simultaneously. If you are still experiencing issues, you may need to perform a restore through iTunes.
Score 1
Add a comment
I just put a 5th generation Ipod Video together from scratch which I have done several times. When I got it together it seemed to work fine when I turned it on and played a song, but I noticed it was slow to respond when scrolling up and down and kept freezing. I tried this (toggling the hold button on and off and holding menu and the center button to reset) and it worked like a charm no more slow response or freezing. Thank you very much!
Add a comment
Add your answer
Tristan will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 2,519
