Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White. This page aims to help users troubleshoot, fix, and seek help for the iPhone 4.
2375 Questions View all
Question Closed
Water damage, cleaned inside, power on, black screen
I dropped the phone in water. I used 99% isopropyl alcohol to clean inside.
The phone is able to turn on because vibrator works when I try to turn it off.
But, the phone still have the black screen.
Thank you
1 Comment
Does itunes recognize your phone? Have you tried a soft and/or hard reset?
by
Add a comment
1 Answer
Chosen Solution
I'd go back and clean the connections again (and again for good luck) for your LCD. Water doesn't always short the screen but leaves residue in the connectors. If your screen when blank has darker areas or an "oil" stain you may need to replace the LCD.
Score 2
Add a comment
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 2,195
