Spilled half glass of water over my Mid 2012 MacBook Pro
Hi!
This just happened to me, the moment the water touched the laptop it turned off (or maybe it just went normally into sleep mode… i’m not sure since i left it in standby for a while before tripping and dropping the glass of water over the keyboard)
I inmediately disconnected the magsafe connector and keep the macbook upside down. I could see that there were some water on the rear vent so I opened the back of it and dried it out with a paper towel (the back cover was a bit wet too) but the mainboard seems to be fine. I disconnected the battery and checked under the DVD drive to see if there was any water, but it was all dry.
I still haven’t turned it on. I’ll leave it with the battery disconnected and the back opened for at least 24hs.
What do you recommend me to do before I try to turn it on again?
If it doesn’t work i can either try to repair it myself (I do have the basic electronic tools so i can check voltages, solder, etc. ) or maybe try to source a broken machine with a working motherboard I can swap with mine, or even try to find a recommended unauthorized tech that has the right tools to diagnose it more thoroughly . I must say that I’m from Argentina, that does complicate things a bit too. (finding spare parts, a good tech service, etc.)
Thanks!
