The original Xbox is Microsoft's first widely popular video gaming system. It has an easily identifiable black case with 'XBOX' emblazoned on the top and front. Repair is easy with common tools.
170 Questions View all
My Xbox won’t turn on anymore. Is it broken permanently?
I’ve had my xbox original for all my life. About 15 or so years. It’s slowly been degrading, cords have worn down, most of the controllers don’t work, and most importantly the power button does not work. The only way we’ve been able to turn the Xbox off as of late is to unplug the cord. I was playing on it as usual and the screen froze with a loud blaring noise. I unplugged the Xbox and plugged it back in. It lit up and began to turn on for a few seconds then quickly turned off again. I tried again by unplugging and plugging it back in and it kept turning on for a few seconds but then quickly turning off. The power cord was slightly loose and you could move the metal parts (which were a little bent) of the plug. I’m not sure if the plug is the problem and I need a new cord or if there is something wrong internally with the Xbox. Or is it broken permanently?
1 Comment:
if the plug pins are loose then likely the power is not reaching the PCB.. you need to fix the power button and the ac input by the sounds of things and then see where you're at. finding a broken xbox is the most likely way of finding spare parts these days. good luck.
by
Add a comment
Avery Sterberger It depends, when you turn on your Xbox Original does the light around the button start flashing red and green? When you turn on the Xbox does it display anything? Does the Xbox even turn on? if your xbox is struggling and it comes up with a screen saying to get your Xbox serviced you may want to get it serviced…. i will look into what your problem is and hopefully resolve the issue but for now just try not to mess with the Xbox
Add a comment
Ok “Avery Sternberger” i found a solution, your Xbox may actually not be damaged for ever but what really is the problem is the cords and the power button (cause of course you dont wanna have to unplug the Xbox everytime you wanna turn it off) i will need you to answer this question if im gonna help you but does your xbox actually turn on? If it does then its a problem with the cords connecting to your television specifically the red white and yellow cords, so you may want to buy some new ones. If your Xbox just does not turn on then there are 1 of the 2 problems the first problem is that the internals of your Xbox may be broken from abuse, the second problem (that is probably most likely to be your problem) is the power cord that may be ripped or damaged in some kind of way
Add a comment
Add your answer
Avery Sternberger will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 15
All Time: 133
