Model A1181: 1.83, 2, 2.1, 2.13, 2.16, 2.2, or 2.4 GHz Core 2 Duo processor
1392 Questions View all
Sleep or shut down?
When not in school my machine pretty much stays at my desk and i dont put much use to it besides video and audio playback. This being said it basically stays plugged into the adapter all day long, should i remove the battery in this case? Another question is, should i shut my computer down every night or put it to sleep?
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
Chosen Solution
no, you should not remove battery when plugged into AC
although it's safe to do so, the MB or MBP will automatically reduce the processor speed when running on AC without a battery - see this technical note from Apple. As the note says, this is in case the computer needs more power than can be provided by the AC adapter alone - as could possibly be the case if you're running a lot of video and the CPU gets heavily loaded.
as for sleep or shutdown - I run my MBP plugged in every day at work for 8hrs, then on battery at home, and always just sleep the machine. There's no need to shut down every day.
OTOH, I would recommend you periodically recalibrate your battery once in a while, to make sure you're getting the best performance out it if.
Score 1
Comments:
Great reference bac, thanx. Now, as far as the sleep vs. shut down what do u recommend?
by
Thanx bac
by
Add a comment
Is there a difference in energy consumption between the two states? That might be enough of a reason to shut down.
Comments:
I believe there is a difference in energy consumption, but while in sleep mode the consumption of energy is minimal.
by
Add a comment
Add your answer
Majesty will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 1,213
