The MacBook family was first introduced in May 2006 and replaced the iBook as Apple's consumer laptop.
3827 Questions View all
Why back display light on MacBook won't stay on? Problem with wires?
My computer is from 06 & I don't have apple care anymore and I may have dropped it a few times. When I use my computer on my lap or on the bed the back lighting won't stay on I have to put the dimmer all the way down and slowly raise the dimmer sometimes it works sometimes it doesn't.. would it be loose wires? or is there permanent damage?
Lately I've been using it on my dresser due to lack of computer desk.. its been working better but sometimes still acts up. any idea what i can do?
Comments:
You have done better than most at describing what is really going on. I find it interesting that it seems to stabilize when sitting on a flat surface with no movement/flexing of the chassis. From the wonderful guide provided by mayer. I can't see how motherboard heat would affect the inverter since it is in the top part of the laptop. But I am not an Apple guru, my background is electronics. If mayer's solution doesn't work my email is in my profile.
by
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
Chosen Solution
Sounds like your inverter is starting to fail as it heats up. Here's how I replace it: MacBook Core 2 Duo LCD & Inverter A1181 (fast method) Replacement
Score 2
Comments:
I wish my answers could this this concise. :p Nice work. +
by
Add a comment
Hola, buenos días Mayer, gracias por tu ayuda y por la traducción. La salida a monitor externo VGA sin problemas, todo OK. Las tres últimas del número de serie: OPO o sino 0P0. Además de la forma de cambiar el cable y el inversor (entrando desde la batería)...qué opinas de llegar al inversor entrando por la articulación del monitor?. http://www.youtube.com/watch?v=Z3-SQeABn... ¿Tienes alguna preferencia/inconveniente de este abordaje?.
Gracias una vez más, un saludo.
Add a comment
Add your answer
Ashley Flannigan will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 5
All Time: 1,439
