The Surface Laptop by Microsoft is the first full laptop in the Surface lineup. Released June 2017.
13 Questions View all
WD Elements SE 1TB doesn't show up on Surface Pro 3 laptop
The USB drive in the Surface Pro 3 laptop is functioning properly. So as the WD Elements portable as I checked from my Window desktop pc, all the files are there.
Only the laptop fails to detect the WD Elements.
Add a comment
Android Fix Kits
A new screen or battery is one kit away.
Shop Now
Android Fix Kits
Shop Now
1 Answer
Most Helpful Answer
You’ll need to check power draw of your drive and what the Surface laptop is offering up. To do this you’ll need this great little tool! USB Mini Voltmeter Using it you can plug it into your other system in series with your drive and do the same on your surface let us know what you find.
USB Mini Voltmeter Image
Product
USB Mini Voltmeter
$9.99
Score 1
Add a comment
Add your answer
nina.uk22 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 3
All Time: 88
