Adding gpu into motherboard
Hey there.
Can i put a GPU chipset in there?. Because, i saw this slot is empty.
Hey there.
companies use some techniques to save money on board printing, including using the same board for multiple devices.
Unfortunately, though the board is printed the same, the PLDs are not programmed to accept an additional GPU unless specifically stated as GPU upgradable in your device spec.
i did a little reading on your acer E1 product, and found nothing mentioning it.
im not saying it is not possible, but from the little research i did, it is not likely that the device is designed to accept a mounted GPU
Hi
No you cant you need amachins and you need to add ram for gpu and some capacitor and resistor and so many ic
So just company's can add.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 47
