Mid 2006 / model number A1181 / black or white case / 1.83 or 2.0 GHz Intel Core Duo processor.
513 Questions View all
My MacBook will not reboot.
The chime sound is made and it will load to a blue screen but nothing else will happen.
Add a comment
Chosen Solution
Hi! You might want to take a look at my answer to this question:
Dropped MacBook
Score 1
Add a comment
Boot into SAFE (shift) mode
If it progresss past the blue screen run Applications->Utility->Disk Utility->Disk First Aid tab: repair disk and repair permissions.
If safe boot fails and you have access to another Mac Target boot (T key) and connect to the other machine with a Firewire or USB cable. Run the same application from the other Mac
Reboo and see what happens.
If this is acceptable please remember to mark it.
Good Luck,
N.
Score 1
Add a comment
Sounds like your RAM isn't in, open it up, and check that it's in.
Score -1
Comments:
If the RAM isn't in, it would more likely beep than chime. It sounds like the hard drive is either not bootable for some reason, or dead. A blank screen after a chime generally means that the computer is looking for a bootable volume but failing to find one.
by
No, a hard drive failure will bring up the same screen a computer looking for a bootable volume- the question mark screen.
by
Add a comment
Add your answer
Courtney will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 1,740
