lcd and digitizer replacement trouble
i have 3gs which had a cracked lcd,bought one off internet fitted and nothing worked...the screen was blank and the digitizer was inop.So after many hours of getting nowhere i put the old screen back in.No backlight but the digitizer worked...so now ive bought an lcd/digitizer combo unit,put it in and again the screen is completaly blank and the digitizer doesnt work.I`ve tried rebooting,taking the logic board out for a full power down and also restoring the phone but to no avail...any ideas before i smash it to pieces?
5 Comments
phill driscoll. go with what pollytintop says and update on here with any change. Smashing your new digitizer is not going to fix it :-). Make sure that you have the right screen. A lot of folks receive he 3g instead of the 3gs. Check the numbers.
by oldturkey03
where do i find these numbers please?
by phill driscoll
definitely check on your order from wherever you got it, also check on the display itself for any manufacturer markings. The seller should be in a position where they can get you a better answers.
by oldturkey03
I pulled apart my phone again today and noticed that the small rectangular connector on my original lcd screen has a larger internal rectangle than the replacement screens i have recived. The give away was that the original lcd connector "clicks" into position and stays there,the replacment lcd connector deosn`t click nor deos it stay in place...hopefully this solves the problem and can get a new lcd and pop it in asap. Will let you all know if it works in due course!!
by phill driscoll
happens to all of us at some time, the only way to tell is when you are installing, visually they are pretty similar. I hope this sorts out your problem!
by pollytintop
