Reset function is not working. Hardware issue?
Hello.
My 5.5G iPod is working just fine apart from one thing. It's not possible to do a 'hard reset' by pressing and holding Menu and Select buttons.
http://support.apple.com/kb/HT1320?viewl...
I wonder if this might be somehow connected with a click wheel insulation/grounding. Recently, I bought a logic board without a 'silver ground strap' (as described here). Also I wasn't particularly bothered with securing the 'ground tab' (link). I assumed plastic face plate would press it against metal framework firmly enough.
Other key combinations like Select+Play/Pause button to enter Disk Mode or Select+Play/Pause button for Diagnostic Mode function properly.
and the individual buttons work as the should? Menu, select, and play/pause work fine only that one combination not working? BTW in your question you use the same combination for Disk mode and Diagnostics. Diagnostics is Select/Reverse....;-)
by oldturkey03
That's right. The individual buttons and combinations mentioned above (I mistyped the one for Diagnostic Mode) work perfectly.
by ptrkmj
