Repair information and guides for the CDMA version of the fourth generation iPhone. Model: A1349 / 8, 16, or 32 GB storage capacity
295 Questions View all
Why did I lose the ringer mute and volume + and - button functionality
I just bought a new battery and the tools to replace it from ifixit and that went ok but I lost the function of the ringer mute and volume buttons on the side of the phone. Is there something in the battery replacement process (everything seemed to go without a problem) that could cause this?
Add a comment
1 Answer
Hi Joseph, I would verify that all connections are being made correctly. Try disconnecting the battery, power draining the device by holding the Sleep/Wake button down for 5 seconds, check LCD, and Audio cable connections, and then reconnect the battery. Check to make sure that the flex was not damaged during the process by either heat or knicked by a pry tool. I hope this helps you out.
Best of luck, Alec
Add a comment
Add your answer
Joseph Wolf will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 32
