Stuck in headphone mode & cant hear through earpiece, only speaker.
I have read all the forums and watched all the videos about how to fix the "stuck on headphone mode" issue and none of them worked. I have no proof that the phone had any water damage but At this point im 99.99% sure that I need to replace the headphone/charging assembly. I just have a couple questions...
First, would a damaged / malfunction headphone jack cause the earpiece speaker not to work due to it being stuck on headphone mode?
Second, everything else seems to work fine except the "stuck on headphone" thing but could it be another hardware issue besides the headphone jack?
Thanks!
UPDATE: FIXED
I trouble shot the issue further by unplugging the headphone/charging assembly from the logic board and booting the phone back up, the stuck on headphone issue went away so I confirmed it was the assembly.
After reseating everything and replacing the connector cover it worked for a minute then went back to being stuck on headphone mode (super irritating) but I knew i was on to something. So I removed and reseated the connectors again but this time without the metal cover that goes over the battery and headphone/charge and it worked! I left it like that and put the phone back to gather and used it for a while, everything worked without issues. Somehow that metal cover was pushing the connector wrong and causing the issue. I bent the metal cover a bit so it created more tension when I tightened it down and everything works perfectly (for now).
SOLUTION: The metal plate that covers the battery & headphone/charge port connector was our of alignment and somehow causing the "stuck on headphone" issue. Adjusted it and bent it slightly and had no more issues.
2 Comments
Is something stuck in the headphone jack?? I've had pieces of broken off headphone cables stuck inside it and just had to get it out. But it could also be an issue with a bad headphone jack, and in that case, it needs to be replaced.
by Victor Bäck
Unfortunately cleaning it didn't work, there was some lent in there but it didnt make a difference. I even powered the device down and cleaned with a slight bit of alcohol on the Qtip. Im pretty sure I have to replace it. Do you think replacing the headphone/charging assembly will fix the earpiece not working too?
by Travis
