Device partial charge to 50%, runs off battery, no light on magsafe
Hi, hoping someone can give some advice.
I've done a lot of research on battery / charging issues, but I just wanted a further opinion before I proceed as I've seen a lot of variance on these problems both in their issue and the fix.
My Macbook Pro A1502, board 820-3476-A, has an odd issue that I'm not sure how to approach. This laptop was left with absolutely no charge in the battery for a time, and on returning to it, the magsafe went orange, and never came back on, and will not wake-up the device.
I did manage to charge it by leaving the magsafe there until it started, but now it only charges to at most 49% before the charger supplies 0Watts. If I run it down low, the laptop will report a normal charge, until it approaches 49%, after which it drops to 0.1, and finally 0Watts. The laptop will then run off the battery without issue. It will also run with the magsafe attached, and will maintain the 49% charge until I begin using it on battery.
All battery information from Coconut Battery (or equiv) reports normal operation. OSX battery indicator states "not charging", however has lightning bolt symbol and does indeed charge.
My question is:
Could it be a calibration issue (the battery is 5years old) and the 49% is in fact the new 100%, and the laptop just isn't aware of this? Could it be a magsafe DC board issue - the board is slightly corroded, and the magsafe adapter itself does not light up. Could it potentially be a component (J7000, U5000, U7100)?
The main reason I ask is because I've seen conflicting advice, and if I re-calibrate the battery (letting it die completely etc) it might never come back on again. I'm also not hugely experienced with the specifics of what readings I should get from a multimeter should I need to do that with the board.
Any advice would be appreciated.
2 Comments
Update on this. I've ran the Apple Diagnostics, and it reports that my charger was not analyzed/detected and there may be a problem.
Based on some other research, I think there may be an issue with the ADAPTER_SENSE / SYS_ONEWIRE. The DC in board is the only component I see that's corroded, so it's entirely possible that there's a problem with either Pin 6 of J7000 or Pin 5 of U7000. That would probably make sense as the laptop still gets power, it's just not able to interface correctly with the SMC (which is probably why SMC resets do nothing).
I will try and replace that and see if it helps.
by Dusty
Another update.
I've run ASD on the laptop and it has reported two failures.
Sensor Failure = Current (IPBR) - reading below limit (value = 0.409180).
Sensor Failure = Current (ISDC) SSD 3.3V - reading below limit
I disassemble the laptop to remove the board so I can take a look for any obvious signs, particularly on R5429 for the IPBR error. I'm not sure what to look for yet on the ISDC failure, but I will hopefully figure this out as I'm not expecting any help on this question. I will keep updating though in case someone else comes across this issue.
by Dusty
