Released September 16, 2016. Model 1660, 1778 Available as GSM or CDMA / 32, 128 or 256 GB / Rose gold, gold, silver, black, and jet black.
2264 Questions View all
iPhone Battery showing random number and restarting
Hello, my iPhone fell down hard and after it started restarting and getting the battery from 50% to 10% then 13% and again random numbers. After I changed the battery and keep doing they same thing. Anyone knows the reason of this ? And a way to fix it ?
Add a comment
Chosen Solution
Based on history, "the battery percentage is jumping around after a hard drop" I would conclude one of the following:
- The original battery's connector snapped - not very likely, and ruled out since battery replaced;
- The battery connector on the board snapped - possible, though for me personally it will be a first - will need re-soldering the existing one or replacing it;
- The gas gauge line or the charging circuit in general got damaged - need trouble shooting at board level.
The type of damage can be: a cap partially shorted due to spike in current during the drop, broken trace, damaged charging chip, etc.
Score 3
Add a comment
They may fall hundred times and still work or fall once and go bad.. despite all Apple efforts to make them rock solid iPhones are not made for falling. If battery replacement didn't change the picture it's likely some component in charging circuit was damaged or dislodged by the hit. You'll need an experienced micro-solderer to take care of your phone.
Score 2
2 Comments:
I agree with the diagnostic but the solution is in question. Are there things the OP could do to help with diagnostics first?
by
@mayer Nothing that I can think of out of a lab workdesk. But maybe @rany or @refectio can come up with something, they're certainly better than me on iPhones diagnostics.
by
Add a comment
Add your answer
Kalliopi Peridi will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 10
All Time: 264
