Released April 2010 / 2.4, 2.53 GHz Core i5 or 2.66 GHz Core i7 Processors
591 Questions View all
Broken WIFI/Bluetooth adapter metal part!
Fellow Awesome People,
My macbook bluetooth was not working.
after a closer look, i noticed that circled cable socket (attached PIC) is broken and 1 out of 4 soldered legs is not making the contact with the motherboard
the issue is that it has broken out with the path piece and therefore i cant resolder
i have pointed out the damaged leg on the 2nd pic
any one can point me out to the diagram of BCM943224PCIEBT airport card ?
or any solutions how to jump this ?
much appriciated !
please note WIFI is fully functional .
Add a comment
1 Answer
Chosen Solution
Sorry time for a new board ;-{
The logic board is layered so there is really no location to solder the inner pin if the part has lifted up tearing the trace foils. RF lines shouldn’t be altered as all you’ll do is interfere with the emission control so it doesn’t radiate outward at the antenna not at the board internally.
Here’s the replacement: MacBook Pro 15" and 17" Unibody (Mid 2010) Airport/Bluetooth Board
MacBook Pro 15" and 17" Unibody (Mid 2010) Airport/Bluetooth Board Image
Product
$29.99
Score 1
2 Comments:
Thank you dan for the answer. i appreciate the advice.
Since you see to really know about these stuff, would you please look into my other question. much obliged
MBP 2010 MID R5280 & R5281 Location!
by
Thilina - Arbaman's is spot on you'll need to get the schematics & board views so you can first locate what is failing and then ID the needed part/s.
Sorry to say without having the board in front of me I really couldn't answer this effectively as all were doing is playing Whack-A-Mole remotely. Somethings we can do that but a shorted out board is a very different beast as I don't know what you damaged remotely.
by
Add a comment
Add your answer
Thilina Gdna will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 112
