4-inch iPhone released in March 2016 with similar hardware specifications to the 6S. Available in Silver, Space Grey, Gold, or Rose Gold with 16/32/64/128 GB storage options. Model: A1662 and A1723
1049 Questions View all
iPhone SE will only turn on when plugged into outlet, does not respond
When plugged into outlet, will show the plug into iTunes screen. The second I unplug it, it dies. Battery doesn't seem to hold a charge (I just put in a new one).
When plugged into a computer (both MacBook and iMac), phone will not turn on, cannot get to the iTunes plug in screen or Apple logo. I can put it into DFU mode but then gets stuck on "Waiting for iPhone" status in iTunes.
Any thoughts?
Add a comment
1 Answer
Chosen Solution
Sounds like the logic board might damaged, but it's hard to suggest anything without any info on iphone's history. Not to let anything untried you could try replace the lightning connector..data/power flow through it on the way to itunes and power ICs and since it's an inexpensive part it would be good to rule it out as a possible faulty component. An inspection of the relevant connector on the logic board would be needed too.
Score 3
1 Comment:
Going to get a new lightning connector and test it out. Will report back!
by
Add a comment
Add your answer
Chris will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 67
