Explore comprehensive repair and disassembly guides for a wide range of food-cooling appliances. This is your go-to solution for troubleshooting and fixing refrigerators, fridge-freezers, and other cooling units. Whether you're dealing with common issues or looking for step-by-step instructions on specific models, our detailed guides cover everything you need to keep your appliances running efficiently. Perfect for both DIY enthusiasts and professional repair technicians.
1647 Questions View all
fridge got warm, but the freezer stayed nice and cold
I have a small apartment sized Haier fridge. Everything was working GREAT until I dropped something behind the fridge. Then my fridge got warm, but the freezer stayed nice and cold. I removed the big tray that fell behind the fridge and still no cold air in the fridge. Thinking this might be a coincidence bc I am noticing a LOT of frost in my freezer which is not normal. My fridge was only $400. How much do these repairs cost? I live in a small area where I'm sure they will charge me an arm & a leg to fix. Perhaps I should chuck this (donate to someplace) and get a new one? I'm a little handy but there are so many variables I'm not sure I can figure this out on my own.
4 Comments
Hi,
What is the model number of your fridge?
by
i have the maytag side by side model number MZD2766G.My freezer working fine but fridge is not cooling down.
by
Hi my freezer is cold but the fridge is sometimes cold and sometimes not . can I know what is wrong with my refrigerator?
by
@nadya mohd
What is the make and the full model number of the refrigerator?
by
Add a comment
Most Helpful Answer
Cause 1
The Evaporator Coils are Frosted Over
The defrost heater assembly turns on a few times throughout the day to melt away any frost that may have accumulated on the evaporator coils. If the defrost heater assembly is defective, frost will continue to accumulate on the evaporator coils, and the coils will become plugged with frost. If the evaporator coils are frosted over, the airflow through the coils will be restricted, causing the refrigerator not to cool. Check the evaporator coils to determine if they are frosted over. If the evaporator coils are frosted over, test each component of the defrost system.
Cause 2
Evaporator Fan Motor
The evaporator fan motor draws cold air over the evaporator coils and circulates it throughout the freezer. If the evaporator fan is not working, the freezer or refrigerator will not cool adequately. To determine if the evaporator fan motor is defective, try turning the fan blade by hand. If the fan blade does not turn freely, replace the fan motor. Additionally, if the motor is unusually noisy, replace it. Finally, if the motor does not run at all, use a multimeter to test the motor windings for continuity. If the windings do not have continuity, replace the evaporator fan motor..
Cause
Damper Control Assembly
The air damper control opens and closes to let the proper amount of cold air into the refrigerator compartment. If the damper does not open properly, it won’t let enough cold air into the refrigerator. Check the damper control to determine if it is broken or stuck closed.
Score 1
Add a comment
@Sudesh Pall
There are 4 different variations of your fridge model.
Click on your particular model to find the parts diagrams for the model.
Then you need to check as shown in the answer above as to what the problem may be. The parts diagrams will show where each component is located e.g. defrost heater, evaporator fan etc.
If there is an ice build up another thing to check if the heater and the fan are OK and what is not mentioned above is the drain tube that leads from below the evaporator unit to the evaporator pan under the compartments near the compressor unit. If the drain is blocked then the defrost meltwater cannot drain away during the auto defrost cycle and will refreeze again when the cycle is finished and will continue to build up until it stops the fan or blocks the air damper chute leading to the refrigerator compartment
Score 1
Add a comment
Start with the easiest things to check:
The door gasket of your fridge may be defect, check it pls
Check the mode of the thermostate https://abc-repair.com/
Look at the backside of the fridge, the condenser coils and clean up the debris
Does the refrigerator make any noise in the upper part? - evaporator fan
Noise in the lower part - compressor fan.
Any way something is wrong with the air flow
Add a comment
Add your answer
azehnder will be eternally grateful.
Past 24 Hours: 3
Past 7 Days: 7
Past 30 Days: 27
All Time: 16,906
