Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
4994 Questions View all
iPhone 6 wont boot after battery and screen replacment
My iPhone 6 was damaged badly so I replaced the screen and moved the logic board to the same model housing of a different phone that was icloud locked.and it turned on. Then I decided to replace the battery and it also worked. I left it connected to my computer for about a day or two because i just forgot about it and then it doesnt want to boot anymore. So i bought a new battery and it still wont turn on and the battery is working because i tested it on another phone. Now my phone doesnt boot at all and doesnt connect to itunes or anything.
Add a comment
1 Answer
Chosen Solution
There are two possibilities here:
  1. You may have damaged something when you transferred over the logic board and screen. Double check your work by following these guides.
  2. If the original phone was badly damaged, it probably had some effect on the logic board. Moving it to new housing only moves that problem over.
What kind of damage did the phone sustain? Was the housing bent or mangled? Because that can cause issue on the logic board at the trace and solder connection level. The board may be repairable but it would require a micro-soldering repair.
Score 2
2 Comments:
Yes there was housing damage around the power and volume buttons but after moving the logic board in the different housing and replacing lcd the phone was working fine again with the exception of the touch id
by
Also the lcd was broken as this phone was thrown
by
Add a comment
Add your answer
Emad Milek will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 54
