Everything you need to repair your iPhone yourself! From the newest iPhone 15 lineup, all the way back to the original iPhone 2G released in 2007, iFixit has free repair guides and disassembly information for every single iPhone, as well as the best replacement parts, tools, and tips in the galaxy.
36444 Questions View all
iPhone X and 7 get warm-ish
This happens on my 7 and X seperate apple ID's as one is for business
When I put my iPhone against my skin specifically he top right corner it feels warm. I borrowed a thermometer from a friend and t was reading 88-91 when using reddit, safari, and outlook for about 20-30 minutes.
I’ve read some people say it’s normal and others not so I was hoping some people could let me know or actually check the temp of there phone after 30 minutes of moderate use? Could it be hand heat even with a case on?
Thanks!
Room temp varies from 70-75
Add a comment
1 Answer
Chosen Solution
I've never measured the temperature directly but warm to the touch is fine and normal, especially under moderate to heavy use. If the housing gets uncomfortably hot, then there is something wrong.
Score 5
4 Comments:
Would it be possible for you to measure and see? Just to put my mind at ease its never super hot just warm roughly 88-90 after 30 minutes of safari, facebook, and reddit.
by
I would deeply appreciate it...
by
I had submitted a contact request on your website hope to hear back soon and I will close out this ticket thank you.
by
I’ll see if I can get around to measuring the temperature but keep in mind that the logic board already has 4 temperature sensors spread out across the board. They are generally set at somewhere between 60 - 80C so if your board was excessively hot, you would see a warning message on your screen.
by
Add a comment
Add your answer
Caden Brewer will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 61
