The Apple iPhone 5c was announced on September 10, 2013. Repair of this device is similar to the previous models, and requires screwdrivers and prying tools. Available as GSM or CDMA / 8, 16, 32 GB / White, Pink, Yellow, Blue, and Green.
1358 Questions View all
Screen ribbon plug will not seat
The screen has 3 ribbons that need to plug into the phone. The first one snapped in fine. The second plug would not snap in. I tried snapping the original screen and it snapped in with no problem. I was not able to install the new screen.
Add a comment
1 Answer
Inspect the connector on the phone and on the screens. If the old one snaps in fine then it's possible that the connector on the screen is damaged.
Comments:
Or it could be that the OP is trying to plug in a 5s screen on a 5C which use different connectors.
The 5c screen has an extra screw hole at the top right that screws into the metal back plate that goes behind the screen.
by
You're right. I forgot about that. I usually compare the size of the black plastic part near the top of the phone. The 5s is thinner than the 5c
by
Add a comment
Add your answer
Douglas Feltkamp will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 33
