Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 16 or 32 GB capacity / black or white plastic back.
1952 Questions View all
No service, which antenna do I need?
I recently dropped my phone and now have service that is very in and out. I opened the phone and couldnt find any disconnected cables. The wifi still works all the time. Which antenna do I need to replace? I currently have the replacement antenna which wraps around the back of the dock connector. I've also heard that the antenna is located in the headphone jack assembly? Which should I replace to restore cellphone service? Thanks!
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
Chosen Solution
the dock connector flex should sort the problem out.
iPhone 3GS Dock Connector Replacement
Score 2
Add a comment
Did this solve your problem ? I am suffering from the same
Comments:
I did no answer to it
by
I see, sorry about that. But you posted both at the same time. Sometimes it takes a bit for the experts to see that you are asking. pollytintop and Brad are the iphone guru's and I am sure they will answer your question soon. Good Luck
by
sometimes we sleep....sometimes there is life outside of ifixit! cheers oldturkey, I've answered the original post.
by
yes you have, another wonderful job my friend. ;-)
by
Add a comment
Add your answer
Gerard Libby will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 2,059
