I replaced the Keyboard and the keys register for other keys.
I just replaced the keyboard on a MacBook Pro for a friend and the keys are reversed. The cap lock only works with the right bracket button and the control keys at the top, volume spaces, etc..., are working in the wrong order. Is there a fix for this other than a new keyboard?
Comments:
You haven't set the keyboard to Arabic or something like that? Ours isn't quite so bad but many of our keys seemed scrambled apart from letters and that was the problem...
by
Well it's set to english and it only effects the F1 to F12 keys and the Cap Lock key only works with the left bracket key.
by
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
1 Answer
Chosen Solution
It sounds like your ribbon cable is not properly seated,see picture here, sitting off kilter a little bit. Both of cables need to be in there straight and true. Sometimes they look like they should be good with out close inspection, but they are not. Also make sure the black flap that holds the cable in is flat and straight. Sometimes they want to bow out in the middle.
Score 2
Comments:
OK, I just replaced the keyboard with another new one and reset the ribbon cable with no result. The same issues are still occurring, this is driving me a bit nuts.
by
Reset your SMC - System Management Controller - http://support.apple.com/kb/HT3964
by
Thanks but it did not work. Is there a way to remap the keyboard?
by
Please see machead3's solution and apply it to your operating system: Macbook Pro Replacement keyboard - F Keys are in the wrong place
by
Add a comment
Add your answer
Michael Perrick will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 1,641
