Water will not come out part time
Won't fill with water until playing with multiple knobs over and over. Eventually will start working. Hot/cold valve recently changed.
Please explain your statement about changing the hot and cold water valve.
Cause 1
Water Inlet Valve
The water inlet valve opens to allow water to enter the washing machine. If the water inlet valve is defective, the wash may fill slowly or not fill at all. The water inlet valve requires sufficient water pressure to function properly. First, check the water pressure to determine that it is adequate. If the water pressure is adequate, try cleaning the screens inside the water inlet valve hose connection ports. If the washer still fills slowly, replace the water inlet valve.
Cause 2
Low Water Pressure from House Supply
The home water pressure might be too low. The water inlet valve requires at least 20 psi to function properly. Check the water pressure to the valve to determine if it is sufficient.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 30
1 Comment
@asonnier2 what is the exact model number of your washer and why did you change the hot/cold valve?
by oldturkey03
