The Xperia Z1 Compact is Sony's premium camera phone. It is similar to the Xperia Z1 model except smaller and less expensive. Its key feature is a 20.7 megapixel sensor. Upon release the available colors were white, black, pink, and lime. This device can be identified using the model number (D5503)
29 Questions View all
I dropped my phone and the touch screen does not work
I dropped my Sony Xperia1 compact. The date and time still shows up, and so do messages from Xperia, but the touch screen does not work at all.
Score 1
Add a comment
1 Answer
Most Helpful Answer
@griselda sounds like a broken digitizer. In that case you would still see your screen but can't do anything with it. Unless you have the right tools Like a LCD/glass separator etc. I suggest that you replace the complete assembly. Use this guide Sony Xperia Z1 Compact - Display Assembly Replacement Replacement for that. You are going to get links posted on just replacing the glass/digitizer but it will require special tools and skills to do so.
Score 1
3 Comments:
Thank you very much old turkey. I will all a friend to help me do this.
by
I mean ask a friend
by
@griselda sounds good. Best of luck to you.
by
Add a comment
Add your answer
Judith Hamilton-Sayer will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 1,144
