Model Number A1707. Released June 2017, this MacBook Pro features Kaby Lake processors up to the 2.8 GHz quad-core Intel Core i7 processor with Turbo Boost up to 3.8 GHz.
324 Questions View all
How do I move my Windows 10 Bootcamp partition to a new drive?
I have a Windows 10 which I’ve already activated on a Bootcamp partition in my MacBook. I want to move this partition to a new SSD for my new PC, which I just finished building.
I don’t intend to move OSX to the new drive, just Windows. This way, I can use them inependently without having to purchase a new windows license.
My hypothesis is that I can use a USB-C to SATAIII adapter(to attach the new SSD), and clone the drive once booted into my Windows partition, but I’m not certain this will work. Any advice? I’d appreciate any input.
Add a comment
1 Answer
Most Helpful Answer
Not that simple! BootCamp's Windows Partition is a sub partition within the Mac File System.
I really think you're making this harder than it is. As long as you have a license key you can setup your second system with a full copy of MS Windows & re-install your apps, then You can transfer your Windows data over. Microsoft won't shut you down having both running as long as its not too long.
Score 1
2 Comments:
So basically, I should just use a flash drive installer, then use the same product key I used before?
by
Correct! Just do a fresh install on your other computer with the OS & Apps. Then copy off your created stuff (data). Once done delete the old install from your MacBook Pro so you can use the space for MacOS stuff.
by
Add a comment
Add your answer
Charles Coffield will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 3
All Time: 2,357
