Repair information and guides for the iPhone 6S released by Apple on September 25, 2015. Models: A1688, A1633
2689 Questions View all
No service - No sim , antenna damaged could it affect it?
Hello
i have an issue with this phone is that it shows there is no service even when there is SIM inside , i tried different Sims with different carriers , still the same problem
i want to ask , i found that one of the legs of this antenna is damaged , the one is tightened with screw to the top edge of the phone ( not on the board ) , only this leg is damaged , could it be affecting the problem ? ( attached photo of the antenna )
even though the wireless and Bluetooth is working fine
what could be the problem ? IC or damaged sim reader ?
thanks in advance for your help
Update (05/21/2018)
this metal part is not there , could it be causing the fault
Add a comment
1 Answer
Most Helpful Answer
Can you post a picture of the damaged antenna?
Score 2
5 Comments:
actually i just found that the metal between the pad which the screw is tightened with , and the antenna is cut
could the problem be from it ?
by
please check the update
@benjamen50
by
If I remember correctly that antenna on the top left is used for 2.4/5.0GHz wifi antenna.
The main antennas for cellular Sim signal is the one from the charging port and the other one right side of the screen connectors on the board.
Sometimes these are damaged / ripped after removing the logic board.
by
i checked the places you mentioned , it appears to be fine
any recommendations ?
by
I would start off with replacing that antenna that has the connection cut.
by
Add a comment
Add your answer
Hesham Adwan will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 108
