Model M6497 or A1005 / 500, 600, 700, 800, or 900 MHz G3 processor
117 Questions View all
Dropped, Now won't restart, Can't find hard Disk. Replace Disk?
After dropping this ibook while is was doing a copy, it will startup, but stop when it cannot find the hard disk. The screen lights, but the famous ? shows. I have run the hardware test from the utilities (using the system CD) and the hard disk can't be found. I presume that what I need to do is replace the hard disk drive. Are there other possibilities I should consider?
If replacing the drive is the conclusion, I assume that it needs to be an ATA drive.Thanks in advance for your counsel.
Score -1
1 Comment
Many thanks. I will check connections, etc. Will respond more completely in a couple days - busy here.
by
Add a comment
1 Answer
Chosen Solution
If dropped while writing there is a good chance the drive heads were damaged and you would need to replace the drive. First I would open it up and check for a loose connection of some kind. If not I would replace the hard drive--use this as a opportunity to install a larger drive. Good luck
iBook G3 12" Hard Drive Replacement
http://www.ifixit.com/Mac-Parts/iBook-G3...
Score 2
1 Comment:
Specifically check the connection to the logic board for your hard drive. That can unseat itself pretty easily during a drop.
by
Add a comment
Add your answer
ORGramps will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 863
