Repair guides and support for televisions manufactured by Sony.
743 Questions View all
Red light is blinking but remote not working
Sony 23 inch Red light is blinking but remote not working tv inbuilt buttons also not working what should i do plzz help me
3 Comments:
Ganapathi Production what exact model is your TV? When you sday the red light is blinking, is there a pattern to is or is it continuous blinking? Does anything work/show on the TV? What have you checked? What have you tried?
by
Light blinks five times then rests. Repeats over and over
by
Hi @ mrs.singleton13,
What is the model number of the TV?
by
Add a comment
1 Answer
When you first tried to turn on the TV, I am assuming that the red light was solid which means that it was in standby mode. Turning on the set then ends up showing a flashing red light and no other action. Hopefully the flashing has a repeating pattern of a fixed number of flashes. Please post that count. Also, please post the exact model number of your set. With this information we can provide a more detailed response.
In general, a TV when started with go through some self tests. Any failure or problem detected will result in the set shutting down as you indicate in your initial posting. The set is in an "on" state but in trouble. The set will not react to anything other than a power off.
Please update this with the requested information and we'll assist further.
Dan
Add a comment
Add your answer
Ganapathi Production will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 18
All Time: 4,467
