Released in 2013 Model number: ONETOUCH 7024W FCC ID: RAD386
118 Questions View all
Alcatel onetouch fierce turns on, gets to metropcs screen, thenfreezes
When I turn on my Fierce, it boots up, gets past the alcatel fierce screen, gets to the METROPCS screen, and freezes. letting the battery drain and charging it again does nothing, restarting it doesn't help, and i cant factory reset it. Any fixes to this, that i can do at home?
1 Comment
Model # is 5054N, not sure of the release date or anything like that.
-rgktab-
by
Add a comment
1 Answer
Chosen Solution
Hi,
Don't know if this will work but try and start the phone in safe mode.
I realize that the phone is not technically ON per se, but I'am hoping that if you follow the directions of holding the Power button to shut down the phone that by holding the Power OFF menu option it will then restart in safe mode.
If it does start OK and boots all the way to the Home screen, then a downloaded app is the cause of the problem. The trick is to find out which one.
You'll have to uninstall each downloaded app one by one and test the phone between each download until it finally starts OK 'normally'. The last app that you uninstalled will be the culprit.
Try by uninstalling the ones installed or updated just before the problem started.
If it still doesn't start OK in safe mode, did you try the master reset with hardware keys method of performing a factory reset?
Be aware that a factory reset will erase all your data and downloaded apps. It will restore the phone to its' factory default condition (or last system update condition)
Score 1
1 Comment:
My phone does the same thing but it said android is starting why is it doing this?
by
Add a comment
Add your answer
rgktab will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 974
