What voltage is supplied to the inverter?
I'm removing the display from the iMac g5's case and using it as a standalone monitor. However, I can't figure out what voltage is being supplied to the inverter from the 6-pin connector on the logic board. Any ideas or pinouts?
Add a comment
Chosen Solution
From the PDF: To start L! inverter one needs 3,3V Run on the fi L n°2 the brown one is connected to the 12V Run and the fi L 3 is connected to the GRD the fi L n°1 (not connected) rule the luminosity and is with 0V.
The PDF is in French you can use Babel Fish or your favorite interpreter for the information you are seeking.
Score 1
Add a comment
This answer might be able to help you: Display power inverter pinout or voltage for each of 6 pins needed?
Score 1
AB you might want to make this clearer and enter it as an answer. My answer is just a link. Your answer has a lot more info than mine.
Add a comment
Add your answer
Joel Beeby will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 1,131
