The Kenmore 110 Series is an easy to use home Washing machine created by Kenmore.
496 Questions View all
Water won't shut off and spin problem
Kenmore 400 series washer, model number 11027422600. It will fill and then start it's cycle like normal but the water never shuts off. I have to actually shut off the valve to the washer. Plus now when it goes into spin, it will hardly move at first, I have to open it and turn the tub by hand a little and then it will spin properly. What's the problems if you know?
Add a comment
1 Answer
Most Helpful Answer
Cause 1
Water Inlet Valve
Try shutting off power to the washer while the machine is filling with water. If the washer continues to fill with water even when it is not getting power, this indicates that the water inlet valve is defective. If the water inlet valve is defective, replace it.
Cause 2
Pressure Switch
The pressure switch shuts off power to the water inlet valve when the proper water level is reached. If the pressure switch fails, the water inlet valve will continue to fill the washer tub with water, causing the washer to overflow. Before replacing the pressure switch, check the air tube to the pressure switch to ensure that it is clear of debris and is not leaking.
Cause 3
Low Water Pressure from House Supply
The water pressure to the water inlet valve might be too low. The water inlet valve requires a minimum of 20 psi to shut off properly. If the water inlet valve does not get enough pressure, the valve may not close fully after the power is shut off. As a result, water can leak into the washer and cause it to overflow. Check the water pressure to determine if it is sufficient.
Spinning issue
Cause 1
Drive Belt
Inspect the drive belt to determine if it is broken or if it is loose on the pulleys. If the drive belt is broken or loose, replace it.
Score 1
Add a comment
Add your answer
McQueen will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 1,388
