The TI-84 Plus CE is a graphing calculator released in Spring 2015 by Texas Instruments. It includes a 2.8 inch color screen, USB port, apps, storage, and a 1200 mAh battery.
71 Questions View all
Why is my calculator spontaneously clearing the RAM?
Often times when I turn on my calculator or if I'm just using it in general it will glitch and say RAM clear, when I shake my calculator I can hear a clicking noise. Is there a way to fix it?
Score 1
Add a comment
1 Answer
Most Helpful Answer
Check your battery compartment to see if the contact is loose. It's also possible you have a loose screw which is shorting across things when you shake it around. Carefully pull off the back and then shake it to see what falls out. Make sure you don't loose it in the process! If you can't figure out what it is post an image of it here for us to see.
Score 2
Add a comment
Add your answer
Brianna Castro will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 31
All Time: 1,311
