Headphones socket repair or replacement?
When I plug my headphones, the quality and level or the sound is bad, and I must gently shake the plug to find an intermediate plugging position where it works fine, but it is not steady.
The headphones socket is not faulty : I tried another one and itis the same problem .
I suppose there is a bad contact in the headphones socket on the front of my G4 MDD. Is it easy to fix ? Do I need a new socket ? How do I get it ?
2 Comments
Do you mean you tried a different headphone set?
by mayer
Yes, and the introduction of the 3.5mm jack is very smooth, nearly without resistance : I suspect that the metallic blades inside are bended a little from their original position
by Jacques LUBCZANSKI
