The Grand Prix was updated for 2004 on a revised version of the GM W platform and was unveiled at the 2002 Chicago International Auto Show on February 7, 2002 as the Grand Prix G-Force Concept.
20 Questions View all
Question Closed
2004 Pontiac Grand Prix won't start
Car motor turns but won't start
1 Comment
This question was migrated from https://meta.ifixit.com/Answers.
by
Add a comment
Most Helpful Answer
The first thing I'd suggest checking is the battery, especially if it's 5+ years old. After ~5 years non AGM batteries tend to stop holding a reliable charge. They usually fail in such a way they continue working but the CCA capacity is insufficient for a car to use it. To test the battery, charge it to 12-13V with an external charger to ensure the results are accurate. Once that's done use a battery tester (Same tester but ships with Amazon Prime) to check if the problem is related to a weak battery.
If your battery is healthy, the next likely suspect is the alternator. Test this and see if it's working correctly. This can be done with a multimeter. If you aren't sure how, a tutorial to do it can be found here.
Score 2
Add a comment
sharonsepeda there are a bunch of possibilities. Remember that you need a few things for your engine to start. You said it turns so let us know if it turns normally as it should or slow to start. After that check for spark. If it has spark, you need to check to see if you have fuel. If you have all that you may have a sensor that has failed ie. crankshaft position sensor etc. So to even attempt to narrow it down, let us know what engine model this is and what you have tried thus far to fix it.
Score 1
Add a comment
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 945
