Changed light poped breaker works no more
Frigidaire
Household microwave oven
The power is on but it is dead any resets or fuses
Frigidaire
Yes, there will be a fuse inside the microwave - typically on the power board. Here is an example of one: https://s3.amazonaws.com/f01.justanswer....
With your specific model number, you should be able to find a replacement fuse.
However, you need will still need to figure out why the circuit breaker and internal fuse blew in the first place or more than likely it will happen again. There is a short somewhere. Here is an article that may give you some ideas: https://www.technicianbrian.com/frigidai...
Also, double check everything you did when you changed the light bulb. Make sure you didn't knock any connectors loose/disconnected.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 35
