Released September 16, 2016. Model 1660, 1778 Available as GSM or CDMA / 32, 128 or 256 GB / Rose gold, gold, silver, black, and jet black.
934 Questions View all
Earpiece sounds distorted, even after replacement
Hi there,
as title says, my iPhone 7 earpiece sounds distorted, so i replaced it, but the problem is still there. Are there more parts included which could be replaced?
Cheers
Jan
Comments:
Thanks for the quick response, i'll give that a try...
Cheers
Jan
by
Add a comment
1 Answer
Chosen Solution
Have you tried the other microphones and loudspeaker to see if they appear to work well? The problem may reside in the actual flex cable. You can replace it by following this guide.
However, if this doesn't solve your problem, then the issue could be logic board related.
The iPhone 7 series of devices suffers from issues with the Audio IC and weak traces on the pcb which crack and break. It is a similar design flaw to the iPhone 6 Plus, known as Touch Disease.
Score 1
Add a comment
Add your answer
jmo will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 14
All Time: 80
