MODEL AW0/D 4506 washer has no power changed fuse in plug checked sock
I have no lights coming on on the display the belt is in tacked the water supply is working the drain isnt blocked any suggestions?
Reset the main breaker. There are two or usually they are joined as this machine requires 220 volts. Next unplug the machine for five minutes if the breaker reset does not work.
@steved68 leave the washer unplugged for 10 minutes then plug it back in and try to turn it on. If it does show no sign of life you are most possibly having an issue with the PCB. You do want to take a look at the power cable. Where it enters the washer, it has a power main filter. Start checking there to see if you have the proper voltage going in and coming out. If it is move to the PCB. If it does not replace that power filter.
Take plenty of pictures and post those with your question. It will let us see what you see. Use this guide Adding images to an existing question for that. You will need a multimeter to measure from the power line to the board etc.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 891
1 Comment
@steved68 have you checked the fuses and the power outlet in which the washer is plugged in to?
by oldturkey03
