Repair information and guides for the iPhone 6 Plus that was released on September 19, 2014. Model: A1522, A1524
1525 Questions View all
Vertical lines & unresponsive screen after a drop
Hello.
I have an issue with my iPhone 6 Plus after a recent drop - the screen has vertical lines and is almost entirely unresponsive (when I slide a notification on the screen I see that the swipe is recognized though) and I cannot get through the lockscreen as the Touch ID is disabled after rebooting and you have to put in your passcode manually and that does not work.
You can see the wallpaper with the lines on them and then shortly afterwards all the lines cover the entire screen, then the screen goes black.
Worth of mentioning is the fact that the screen was replaced by a third party a year ago or so as it was heavily cracked in places - but it still responded to touch even after that.
I've watched this YT video - https://www.youtube.com/watch?v=ny8mHGHX... - and took apart my phone as per instructions and made sure that all 4 of the connectors are properly secured - they all were and unfortunately the issue is still present.
This was my first attempt at DIY and although it did nothing I am not discouraged - I would be very grateful if you could point me in the right direction as at this point I simply have no clue what to try next. I am short on cash so buying a new iPhone isn't possible but I think I could afford spare parts, unless of course they cost almost as much as a new phone.
Also if there are any users from London here, any idea how much it would cost to get that fixed by someone?
Cheers.
Score 1
1 Comment
Time to replace the screen. A 6 Plus screen assembly is around $30-$50 US (depending largely on the quality of the screen) and if you already managed to open it up and check the ribbon cables, you're about halfway there already. Just be careful with moving the delicate cables over.
by
Add a comment
Chosen Solution
As Steve suggested, it's probably a defective screen. That's the first thing to try. To respond to your secondary question, the Touch circuitry is on the logic board and the 6 Plus is well known to suffer from Touch related issues. So if a replacement screen doesn't work, then it will require a micro-soldering repair.
Score 1
Add a comment
Most Helpful Answer
Norgannon,
Unfortunately it does seem like you will need to replace the entire front display assembly.
You can follow this tutorial: iPhone 6 Plus Screen Replacement
And use this part (it comes with all the small pieces and the tools required for the repair):
iPhone 6 Plus Screen Image
Product
$59.99
Score 1
Add a comment
this is my phone right now.
1 Comment:
did you get it fixed? is there a way to get this fixed? my phone looks just like that, i can sorta see the background but my screen touches itself and disables itself every time the screen gets turned on. it would be amazing to know if i can get it fixed and backup all my data. one place said they can't fix it already :(
by
Add a comment
Hey!!! Norgannon,
This is Shubham, I am having the same problem with my iPhone 6,
I have attached an image with the comment.
I have done screen replacement but still, the problem continues, unresponsive touch and half a cm verticle lines on the bottom of the screen…..
looking forward to your reply.
thank you.
the touch works fine until the lines become bright white and then it is unresponsive.
Add a comment
Add your answer
Norgannon will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 14
Past 30 Days: 79
All Time: 20,065
