A 49 CC gas powered scooter.
17 Questions View all
My RPM's are getting very high at about 40 MPH.
I have a 49cc gas scooter and I'm having a little bit of a problem. When I hit about 35 MPH my RPM's jump between 9 and 10,000 and it wont allow me to go above 40. Also, it gives me kind of a "jumpy" feeling when it does so. Every now and then this will subside and run normal, but not for an extended period of time.
Add a comment
Spread Fixmas Cheer
Get $12 off your purchase of $50 or more with code FIXMAS12
Spread Fixmas Cheer
1 Answer
Chosen Solution
I just built a similar scooter from a box of parts someone gave me. I had the same problem. There should be 2 screw needles on the carburetor right next to each other. One is the low speed adjustment and one is the high speed adjustment. Your problem is the high speed adjustment. The needle closest to the motor is the LOW speed adjustment. So you need to adjust the one that is closer to the air filter (further from the motor). The way to do this is to put the scooter up on a block so the rear wheel can turn without it touching the ground. Start the scooter and let it idle. Once you have a screwdriver on the high speed screw, rev up the motor as far as it will go. Full open throttle. Now turn the screw a half a turn in either direction and notice how the motor sounds. If it gets way worse, turn it in the opposite direction. Eventually you will find the smoothest position of the needle. Meaning the motor is running smooth and not popping or running badly. You'll know when you get it right. IF you do all this and it still doesn't get any better then you need to get a rebuild kit for the carburetor. It might not need to be completely rebuilt, but since you have to open it to clean it you might as well put the new parts in. If you have a Walbro brand carburetor, DO NOT use an air compressor to blow stuff out of it. Use carb cleaner and an old toothbrush or whatever you can to get it clean. Just no hi pressure air. There is a one way valve in the carb that gets damaged every time if you use air. Once this happens, you will need a new carb.
If this is all beyond your mechanical abilities, take it to your local small engine shop. It shouldn't cost you more than $50 to have the carb rebuilt. Good Luck!!
Score 3
Add a comment
Add your answer
Zach Mauer will be eternally grateful.
Past 24 Hours: 6
Past 7 Days: 20
Past 30 Days: 81
All Time: 3,606
