Toshiba Z40 . power indicators blink 2x amber and 2x white and so on
Toshiba Z40 . power button indicators blink 2x amber and 2x white and so on.
laptop does not turn on.
stuff that I tried.
1. power adapter. working. checked on the different laptop
2. reset. remove battery and power. press power for 1 min. no luck.
3. reseat memory stick.
4. unplug battery ,cmos and power .left it overnight . no luck .
5.tried with battery disconnect and charger connect. no luck
tried with battery connected and charger disconnect . no luck.
battery is fully charged
3 Comments
SOLUTION-- . Faulty Memory stick causing light to blink s 2x amber and 2x white
by work email
I have the same problem on my laptop toshiba u920t ultrabook. The stuff that I tried is 1,2,4,5. I could not try 3. one because I can not understand what memory stick is. My battery is not embedded. Even so I tried you mentioned. How did you handle this problem
by furkan öztürk
Just Change Ram Slot and CMOS battery(cell)
by Umer
