2.26 or 2.4 GHz / White plastic unibody enclosure
618 Questions View all
Can I change only the keyboard of my MacBook?
Hello,
The keyboard of my Macbook Unibody A1342 is broken, and I want to change it. My question is : Can I change only the keyboard or should I change all the top case ?
Thank you for your help.
Regards
Emmanuel Iturbide
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
Chosen Solution
Sorry, it's built into the upper case: MacBook Unibody (Model No. A1342) Upper Case
Score 4
Add a comment
Yeah pull that beast apart get it off however you can , sand down the remaining plastic nubs. Get you a a1278 keyboard pop the black keys off pop the white keys back on glue into place and your in business!
Score 1
Add a comment
if so, then what for they are selling just keyboards?
http://www.ebay.de/itm/180689221352?ssPa...
Add a comment
It is doable, I've pulled it apart myself. The keyboard is held in with glue and plastic tabs. These tabs (almost like rivets) will break when removing the keyboard, so you'll need to find a way to re-secure the keyboard. If you're not picky about a potentially "loose" keyboard, you could do replace JUST the keyboard.
Comments:
also, due to scarcity of the keyboard for the particular model, i found that the keyboard for 2009 a1278 macbook unibody fits just right. costs fraction, too... (at least the UK model)
apart from the ribbon for the powerbutton being traced slightly different way, it is identical.
i know the keyboard is black, for me it doesnt matter.
also, you could use just the traces, if you dont mind a bit of the dirty work.
rivets can be done by heating them and pulling the keyboard up slowly...
just a thought...
by
Ive done it last week. Had to cut and sand the rivets off but in the end i have got fully working topcase. Its a dirty job, not for faint of heart. Ripping the plate off of the topcase looked more like breaking it, luckily plastic does flex alot. As a adhesive i used epoxy.
by
Add a comment
Add your answer
DeWaRs will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 2,187
