Model A1312 / Mid 2010 / 3.2 GHz Core i3 or 2.8 & 3.6 GHz Core i5 or 2.93 GHz Core i7
265 Questions View all
What replacement superdrive do I get?
my superdrive after lil over a year of use is not reading DVDs, Apple dvd or any Program DVDs but can burn dvds and cds. I want to replace it but i need to know specifically what will work with the imac before i buy one.
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
1 Answer
Chosen Solution
It's best to replace with the brand you have.
Model iMac Intel Model with a Pioneer Drive already fitted. May not fit properly if HL, Panasonic or Sony Drive already fitted in your iMac as drive bezel / mounting plastic will be different from a Sony one. The bezel can be made to fit any drive by cutting off 2 dimples of plastic on the back edge of the bezel though.
Mine is The Pioneer DVR-TS08PB Apple Part# 678-0573C
also listed are:
Manufacturers ID: Sony AD-5670S 678-0575E Pioneer DVR-TS08PA 678-0573
Score 3
Comments:
will i have to open mine up to determine this?
by
You don't have to open it. Go under the Apple in the upper left hand corner to "about this Mac". Click on "more info" > Hardware > ATA. This should give you a description of the optical drive.
by
Add a comment
Add your answer
shawn alfaro will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 3
All Time: 2,265
