My MacBook is not reading discs and beeping loudly?
I have a Macbook version 10.6.7 and I think my disc drive broke. When I insert a disc it will make the normal loading sounds, then it will start rapidly beeping really loud. It eventually stops but starts again. If I want to eject the disc it will not let me until a certain point in the beeping "pattern". It also will not recognize the disc by putting the little disc icon on the desktop screen. What is wrong with it and do I need to get it replaced?
Also, when it beeps it has a distinct pattern. Which is below
Disc is inserted and it makes normal loading noises, then it begins to beep, then stops for about 3 seconds, continues to beep, then stops all together. Then a few seconds later, the entire process begins again. I can only eject the disc after the pattern ends.
Please help!!!!!
3 Comments
How many beeps in a row does it give?
by mayer
You are quite possibly right!
This could be the optical drive failing
by Nick
Paige....try with different Media. If problem persists, then replace the optical drive. Make sure there isn't any debris or labels which may have accidentally came off a CD inside the drive. This can also prevent the drive from reading any media.
by Majesty
