Weak wifi signal after iPhone disassemble?
I use the iPhone at the place before where the signal is 3. But now the signal is 1-can't connect Help please.Thank you very much.I removed the logic board.
You need to check connector 5 is on properly (small pin like connector) and also the gold prong near do not remove sticker is making contact with metal frame of phone.
Was this problem there before you opened the phone?
Does it has anything to do with cable #6?
my mistake...no.6, not no5
the gold antenna only needs the tip in contact
The gold prong is now in contract.But still doesn't work.The cable 6 is connected but I have a hard time inserting it.
Is it possible that I connected incorrectly?How can I check?
has anything happened before wifi stopped working? did you update/jailbreak/drop?
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 4,121
2 Comments
The problem happens after. I see... the gold prong is not in contact with the metal frame so I need to bend it to make contact?Thanks.
by um4a
Do you mean I have to make the whole gold prong contacts?
by um4a
