dishwasher won't drain ... at all.
Thinking the hose may be clogged, I disconnected the hose at the garbage disposer, and using a vacuum ... wet drytype, I was able to suck water out and hoped to release any clog. Didn't work. Then I tried to blow air backwards, and noticed it won't go backwards at all.
I hear the motor trying to pump water out, so I think it is working. Reading other answers, I noticed one solution is the drain solenoid ... which opens the valve so water can be pumped. Can you tell me .. if there is any type of ONE way valve in a Samsung dishwasher, preventing any water or air going backwards through the drain tube? IF a clog exists, jamming the pump internally, should I be able to clear it when I remove the drain? I am hoping to avoid buying a new pump if it is simply the drain solenoid. Let alone .... a new machine, LOL. Thanks in advance for your thoughts. CJB
